Refurbishing front wishbones guide
Hi All,
My XK8 needs a few front suspension parts (front upper and lower wishbones, tie rod ends, antiroll bar etc). I already ordered them through the local jag dealer - they offered a discount and the price is better than the refurbished ones.
However, i don't want to throw the old ones as i'd like to refurbish them. I saw this service is offered by a UK company (Berkshire Jag Components) but i was thinking to do it locally (i'm sure i can find a local performance shop able to do that). Question is where should i source the bushes from?
Thank you
Thank you
Use Powerflex polybushes (the blue/purple ones) - they are easy to fit (although the Jaguar OEM bushes are not so easy to remove) and work very, very well. You'll have heard of problems with other makes of polybush (noise, vibration, harshness) but I have been a Powerflex user on multiple cars over the years, and have never regretted fitting them.
Companies such as Eurocarparts.com will stock them. Just make sure they are Powerflex and not some other make, they are not all equal in my experience !
Powerflex - Performance Polyurethane Bushes
The problem with the 4 Wishbones is the ball joints are likely bad. Unless you have a 12 ton or larger press, you are going to spend hours, if not days, trying to remove/install the ball joints.
Refurbished wishbones are expensive due to the ball joint labor. The Bushings are the easy part.
Thank you.
The Balljoints are readily available and cheap in the UK. I did my lower balljoints in January (I have a 20 Ton press) and they came from the UK (via Rockauto.com). They were less than $20 USD each.
In the US, Local Autoparts chain stores don't carry the lowers (likely because they are so hard to DIY) and shipping them in from the UK was cheaper than buying them from Jaguar Specialty retailers.
That's a steal! Took me hours to get 2 of mine to pop out and I still think I have hearing loss from the bang. I love the purple powerflex bushes I put in mine.
I agree $40 is a steal, especially if that is old out/new in... That's crazy cheap. I seriously doubt he'd do it for $40 for the next XK8 guy that shows up.
FS[Western US]: Parting out 1997 XK8 convertible
BobRoy
49
09-18-2016 10:48 AM
FrankZ06
08-28-2016 07:05 PM
