Reliability.
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
I can honestly say that I have not had 'any' problems with it over the 7 years that I have had it.
I will however be installing the hydraulic pressure releif kit on the retractible pump , and replacing the transmission fluid;both as a precautionary measure.
![Icon Naughty](https://www.jaguarforums.com/forum/images/smilies/icon_naughty.gif)
Looking forward to many more years of trouble free driving.
PS. I store the Cat in my heated aircraft hanger over the northern winter months.
Have a good trip. No worse than any other car of that age and mileage. Most of the problems you'd run into are the nuisance type unless you run out of oil or blow a hose or something. Good check-up before you go and enjoy. Worse that can happen? Tow truck, motel for a day or two, ? rental car. Relax, enjoy!
![Icon Toast](https://www.jaguarforums.com/forum/images/smilies/icon_toast.gif)
Should be a reliable car. I have a 2000 XKR coupe that I bought 4 yrs ago with 54000 miles that I use as my daily driver. Right now the car is in for a headgasket repair with 117000 miles, besides that, only problems I had were fuel pumps, and water pump. The one issue I did have with the car was people tend to not see or hear the car, it's very quiet, and people cut you off. Driving the car with the parking lights on fixed this problem.
Jim
Jim
dHaven't had our XK8 w 42k miles long enough to say (bought used w 38k miles), but I can speak to our '04 XK8 4.2L which we bought new and now has 110k miles:
1. 14,500 miles: Warranty repair on oil supply problem to variable valve timing apparatus, no charge to us.
2. 77,500 miles: New heater control assembly in dash ~ air volume n temp not even from R to L side, $2,600 ... ouch. Had to replace the whole dang thing behind the dash.
3. 100,000 miles: New speaker driver side on dash, $100.
That's it. Everything thing else is routine maintenance and disposable items.
So I'd say they're pretty reliable.
I did almost a thousand this summer in my 01 with 39K. Had some coolant, oil, duct tape, a spare coil, jumper cables, a spare serpentine belt, and a socket set with me...just to limp somewhere if needed. Would have done the same in the new Lexus or any of the other cars. Had no trouble though!
You should be fine. By 2005MY almost all the issues had been corrected and reliability is great.
