Remote door un/lock
Ny new (to me) '97 8 did not come with a remote fob so off to eBay I went, first getting the wrong one. I found this out by some posts on this forum, thanks!, that suggested I call the dealer, supply my VIN and get the paert number for the correct fob, done. Sent the first fob back, the seller graciously accepted the return and won an auction for the correct model, arrived today.
I follwed the instructions, again thanks to this forum, and managed to get a light flash from the shifter area acknowledging fob button push from ALL four buttons. However, the only three buttons seem to be functional, but not the door un/lock. The other symptom is that there is no chirp during any of this process, just the light flashing in front of the shift lever.
Is there some more trouble shooting/iolation that I can do? Where/what is the electronic module that might fix this?
If the key will unlock the door then the fuse and door module are ok. The Security and Locking Control Module is powered by fuse 10 in the trunk fuse box but if you got through the sync sequence that is also probably ok.
The lock/unlock button gets most (all) of the fob's use over its life and is therefore the first to fail. I suspect that is your problem rather than being a car issue. I have taken the rubber contact pad apart and cleaned it with some success. The chirp is very soft on my car.
Yes, the key will un/lock and when I perform the sync, the light will flash when the un/lock button is pressed. I have taken the remote apart and carefully cleaned everything. Regarding the chirp, with the diminished state of my hearing, maybe it is happening, I'm just not hearing it. The problem however remains, can't un/lock with the remote fob. Anything else I can check?
However, you purchased the remote on eBay. As well as checking the right LJx2610xx number, you definitely did get a US frequency (315 mhz) fob and not a European (433 mhz) frequency?
I appreciate all of your inputs. But I am embarrased to report I have found the problem and it is me! I finally read the security manual last night after I managed to set off the alarm to the displeasure of my neighbors. I now understand how the remote fob functions and the upper left button is not the panic button, as you all know that is accomplished by the lights 3 times, found out the hard way. So all is well, works as advertised and I still find it hard to believe the Jag dealer charges $80 for "programming", they should be ashamed.
Hi all ,
Can amyone help !
Just had my x-type jag serviced , for some reason when i got car back found my osf door panel had been removed , took car back as remote for unlock / lock was intermiten , thought this may be due to panel ? just before car went to garage found spare key to be working fine.
Garage phone to confirm panel was removed and re fit was ok , however i would need new key flob as remote is faulty , is it normal for 2 keys to go faulty at same time or is the fault inside car ?
Can amyone help !
Hi all ,
Can amyone help !
Can amyone help !
dd07 (01-07-2012)
kabs3012
09-12-2015 10:40 AM
