remote locking horn doesn't work
Not an easy one to diagnose, as there are different systems according to model / market etc.
Assuming you mean the little "chirrup" - it comes from a little security sounder just behind the headlight on the right hand side wing. It may be "passive" or "intelligent" depending on whether it is also linked to "tilt sensors" and other stuff. Worth checking Fuse 9 (10 amp) in the engine bay fuse box - if you're lucky, that might be the problem. Otherwise, the most common problem is that there are two rechargeable NiCad batteries in the sounder which, after many years, corrode and do this :
![Name: Alarm%20Sounder%202_zpst5i1metj.jpg
Size: 326.2 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/153270d1501207003-remote-locking-horn-doesnt-work-alarm%2520sounder%25202_zpst5i1metj.jpg)
It is possible to sort-of dig them out of the rubberised potting compound and replace with new, but it's not a straightforward job. Or ............ replace the whole sounder unit with new, but that won't come cheap !! You can look at the wiring diagram on Gus's site :
www.jagrepair.com, under "security and locking". 13.2 if my memory serves !!
I also have a 2001 and on my car it is not the horn that sounds off when remotely locking the car, as it is with most every other car. The fact of the matter is that it is a very low chirp that you can't even hear if you are not near the car. Stand right up close to the car and see if you can hear it. If not, then you will want to follow the suggestions of Devon David.
John S - They did !! It's just that if a thief manages to get into the trunk (boot) to disconnect the battery to silence the alarm, the rechargeable cells in the "security sounder" will keep the alarm sounding.
It's quite a complicated circuit :
![Name: circuit%20board%20bottom_zpsjjt9hqom.jpg
Size: 498.1 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/153251d1501206989-remote-locking-horn-doesnt-work-circuit%2520board%2520bottom_zpsjjt9hqom.jpg)
If everything is working properly, it "recharges" once the ignition is on, and is "primed" by the locking circuit. What can also happen, is that the two NiCads corrode and stop working, thus providing a constant current drain on the battery which is frequently the cause of a low battery after a period of not using the car.
Mine stopped working, I tried to replace the NiCads but the rest of the circuit had also stopped working, so I replaced the unit with a second-hand one. Everything is "potted" in a sort-of rubber compound, so it's difficult to dig out. In theory, it should be 100% waterproof, but it's in a very vulnerable position, so the tiniest bit of water getting in by capillary action starts the corrosion, which then just gets worse !
Edit : In some countries, a "passive" sounder is fitted, which doesn't have an internal power supply, and is much less complicated. I think the only way to be sure is to disconnect the plug to the sounder under the front wing and see how many wires there are, with reference to the wiring diagram.
What I can't understand is with those batteries so badly corroded, why on earth didn't the security module throw a complete wobbly and send a message to the transmission module to tell it to stop working, send another message to the engine ECM causing it to throw a whole multitude of error codes causing a 'Restricted Performance' message whilst simultaneously saying 'Trac Not Avail' and 'ASC Not Avail' and of course locking the boot and fuel filler flap that can only be opened using a dealer level scan tool![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Or am I getting a touch cynical in my old age?
Andy
Andy
DevonDavid (11-22-2015)
Apology and correction ................. it's some time since I did mine, so memory is a bit fuzzy (or is that old age ??).
I think Jaguar used the same loom for both types, so there will probably be six wires on the plug irrespective of whether active or passive. The label and part number on the sounder will confirm which type you have.
alcoed - not sure that what you are suggesting is a practical proposition. My guess is that the BPM (Body Processor Module) is the same in both cases (passive or 'intelligent' sounder) It may be that it has to be programmed - don't know.
I can't see how it could work on a different make and model as the BPM is Jaguar specific. But ........... I'm no electronics / electrics expert, so maybe someone else has a more experienced view of this.
You may well be correct. I have no idea what is inside the "passive" sounder. The two NiCads in series would give 3 volts, and the "active" sounder is designed to work if the car's 12v battery is disconnected, so my guess would be that it is more likely to work with 3v+ & ground, rather than 12v+ and ground. I can't think that the actual "sounder" module (i.e. the bit that makes the noise) is different for 'active' and 'intelligent'.
If you can get hold of one, it would be fairly simple to test. The pin numbers are marked on the wiring diagram.
FS[SouthEast]: XK8 Parts for Sale
glenng
11-21-2015 05:56 PM
kresho.kurtin
11-13-2015 10:50 AM
