Remove rear parcel shelf trim
Well thats what we call it in the UK... The trim under the back window behind the back seat .. Need access to do the fuel pump. Rather than have a go at it thought I would get information. Not sure how the speaker cover comes out ...strange bolts on the underside ....thanks in advance.
Received 2,408 Likes
Pistnbroke (07-04-2022)
While you were typing I prised up the cover and yes 4 clips....then took out the 4 screws and have limited access.
Would like to have taken out the whole rear shelf trim and cut a bigger hole but it looks like 3mm thick board stuck down....my trim looks good but has detached in places.
PS..had another look and may try to get it out and re trim as the material is only £12
thanks again
thanks again
The panel iteself isn't stuck down other than, IIRC, a small flap of the material glued to the front top of the rear bulkhead. The backing is that naff cardboardy stuff.
There's just a couple of flat-head screws behind the rear seat back.
I'm not sure if it will come out without at least releasing the rear quarter panels, though.
Well worth the effort, IMO. I couldn't find the correct colour material (Antelope?) so had it covered with the same as the headlining.
Pistnbroke (07-05-2022)
joycesjag
66
11-26-2016 06:44 PM
