Removing front seat on XK8
I seem to have a short of some kind under the front seat of my 2001 XK8. I keep blowing fuses. Now the seat adjustment and the heater won't work. I was wondering if anyone could give me a step by step on how to remove the seat without the ability to move it forward or back?
Thanks, BobK
Thanks, BobK
Sorry, you're going to have to move the seat forward and back, in order to get to the bolts that hold the rails to the car's frame. They are accessed 'between' the top and bottom rail, so you're going to have to figure a way to get it forward and back. You might have to put a larger fuse in (or bridge the fuse w/o protection, but this can cause permanent damage), and move it just enough to get both directions to work.
First, disconnect the front harness (no idea what it controls) that you can access w/o removing the seat. Then try the controls, does it blow the fuse? can you move it?
If you can get the harness pin IDs, you might be able to disconnect that harness, provide 12V power to the seat controls only... something like that
Thanks for your input. I was hoping there was a mechanical release of some sort. It would make sense from an engineering point of view. Well, the seat is at least stuck in a position that suits me so it should be O.K. until I want to sell the car. As for the heat in the seat, I live in the South now so it's not as much of an issue as when I lived in the North. Thanks again.
Lots of seat control module issues, and pinched wires and blown fuses but I don't think I have ever heard of a motor replacement.
You really can noodle out the connector/motor interface and jump ground and B+ to it to move the seat. I suspect an experienced technician would do just that to move the seat.
99xk8guy
06-05-2023 06:28 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
