Removing fuel sender
Old 06-19-2009, 07:08 PM
eaglexkr's Avatar
Jim,
I just had the sender out in my 2000 XKR and you should be safe at a quarter tank.When your ready to remove the sender,take out the spare tire and put a container under the opening and must of the gas will go into the container.I used a clean oil changing pan.Its an easy item to do.Good luck
Razor
08-28-2019 08:34 PM
dsnyder586
04-04-2019 02:38 PM
1964Daimler
09-09-2015 11:28 AM
deanh
09-06-2015 08:20 PM
AL NZ
09-04-2015 08:39 PM
Quick Reply: Removing fuel sender
