Removing the locking wheel nuts with the key (again)
Old 07-03-2021 | 02:27 PM
drmike's Avatar
Smile Removing the locking wheel nuts with the key (again)
Removing wheel lock nuts without the key - I know this has been gone over many times but I was in the same predicament and after two false starts I got the right tool and it was pretty straightforward. Just get the Irwin Bolt Grip Extension set that has the 19mm socket.
This is for a 2000 XK8 and the locking nuts don't have domes although I suspect that will make little difference if you cut the domes off using a Dremel and chisel.
Anyway I thought I'd share here as encouragement for others!
Mods if this is just repeating what's gone before please delete
Mike
Old 07-06-2021 | 01:47 PM
Mike,
I'm mystified - not by the post but why your Profile shows XK8 Coupe X100 and your Signature shows X300 1994/5 .........
Old 07-06-2021 | 01:55 PM
drmike's Avatar
I can only apologise, I got very muddled setting things up having bought another Jaguar. Initially I had an X300 and stupidly sold it, I now have an XK8. I will try and sort it out.
GGG (07-06-2021)
Old 07-06-2021 | 01:58 PM
DONE - change will appear with your next post.
Redeye
03-06-2016 11:41 AM
mike213735
11-01-2013 11:11 AM
bryans
07-03-2013 06:54 AM
markoscar
01-27-2013 08:10 PM
Quick Reply: Removing the locking wheel nuts with the key (again)
