Removing Sepang 20" wheels-difficult?
I had all four Sepang wheels off, cleaned, Anti-Seized the contact area and refitted when I changed brake fluid in December.
When I came to remove the wheels again to check the brakes during a scheduled service yesterday, the LH rear was solid.![Icon Rant](https://www.jaguarforums.com/forum/images/smilies/icon_rant.gif)
Never had this issue with the Impellars on my last XK8 so I checked exactly what was making it stick. The Sepang appears to be a very close fit on the lip of the hub where it slides into the back of the wheel. On mine, moisture and road dirt had built up with the inevitable bi-metallic reaction between aluminium and steel.
I've thoroughly cleaned the lip on the hub and the inside of the Sepang at the contact point and coated with Anti-Seize. This should prevent it happening again.
Incidentally, I use the Aluminium equivalent of Copper grease on the wheels so the grease doesn't show up on the inside of the wheels if there's any cast off. The Aluminium variety is marketed as 'Zeta Grease' and is available from Land Rover Dealers.
Absolutely not! Heat could kill the finish on the face of the alloy.
If you can remove the centre cap, try a good spray with release oil where the hub meets the wheel:
Sepang R10Jx20.pdf
With the cap off, this area is easily accessible through the centre of the wheel. Release oil should free it up and then it's on to the rubber mallet treatment.
hunter34
19
09-14-2022 11:09 PM
aholbro1
08-05-2021 05:02 AM
