Replace CATS with standard shocks
Has anyone ever replaced the adaptive shocks with standard shocks? I know you can get a kit to do this with the XJR but I have not found a similar kit for the XKR. As these cars age it will become increasing difficult and expensive to maintain the CATS system.
BTW, about how long do the adaptive shocks last before they need replacing on average?
I have the same question. I have a 2004 XKR and the 20" front wheels bottom out on the inner fender lining when I hit a big dip. The car has 58,000 miles on it and has the CATS Bilsteins. Has anyone replaced these with Bilsteins or another shock? I'm quoted a price of about $467 per shock with the CATS. Plus, the plate with like an elastic polymer sandwiched in between, that is like a rubber grommet on most cars, costs $161 each to replace, not including labor. Is it a difficult job to replace the shocks?
Thanks,
john
Thanks,
john
Adaptive shocks were almost 3x the price of non so the guy above got one hell of a deal or they were going to way overcharge for regular shocks. I've replaced my adaptive with standard Blistiens but I did replace the springs with a stiffer rate to compensate to keep a firmer ride.
IF not done already front and back will need top mounts (front it the pancake mount, back are just bushings).
I measured my ride height in front and it was 14.5" and is supposed to be 15.5".
I'm told the pancake mount in front probably collapsed after 58,000 miles. That is likely why the wheel bottoms out on the inner fender shield over large dips. The OEM mounts are around $170 each plus installation. Has anyone found an after market mount?
Thanks,
John
Thanks,
John
