Replace cluster speedometer LJD4300MB - HELP
Guys,
I need some help.....my original cluster on VIN: SAJBA42B8YPA05997 XK8 XKR 2000 Convertible is the model LJD4300MB and needs to be replaced.
I called local dealer and their system said these parts my work but will need a diagnostic tool to probe cluster.....but original cluster is dead!!!!
Here are the part numbers provided by deal:
LJD4300GB or
LJD4300HB or
LJD4300JB
If you have any knowledge or experience on getting the correct cluster, please let me know.
Sergio
original cluster speedometer part number
LJD4300GB or
LJD4300HB or
LJD4300JB
Sergio
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/750x1334/jag_cluster_ljd4300_f6b342ccd8b8a757a993c3c5b3db4b664c963f7b.jpg)
Check the VCATS, Check the VCATS, Check the VCATS, Check the VCATS, Check the VCATS, Check the VCATS, Check the VCATS, Check the VCATS.
My 2000MY XKR boot label info.
IPK LJD4300KB / 104 (supercharged XKR)
Part number might have a different two letter suffix but the /xxx needs to match if that is what your car has.
The 4.0 liter X100/X308 cars do not need config for IPK replacement but the mileage will not be correct.
The 4.2 liter X100 has a VID block and is a WHOLE DIFFERENT car!
Sergio Mastronardi (09-24-2021)
Received 2,380 Likes
Hi,
Have you considered having your existing IC repaired? It's the best route if it can be done at a reasonable cost as you won't have any compatibility or kilometrage issues.
JEPC does show the same # fitted to the X308 within a specific VIN range:
I can't make out the full part # on the 'Visteon' unit you have shown, but it could be LJE4300FB for a later VIN range on both the XJ and XK. Would it work? - possibly.
A quick Google of your part # doesn't return any results other than from Jaguar Heritage, so there aren't many about - but then they weren't fitted to very many cars![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
The part fitted to your car does not have a supersession number, so I would look further for a unit that matches yours (and your VCATS).
@xalty - what's the issue with a mph unit? I'm wondering if a Mph with Kph subscale might be easier to source if the OP draws a blank (if Canada permits this).
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1349x453/x308ic_033f3414b659290a7d940dce537474e9d0f659a3.png)
car5car
10-16-2023 11:42 AM
webbeing
08-23-2014 01:30 AM
Staatsof
53
09-14-2012 08:23 PM
