replace lower tensioners?
I have a 1998 XK8 approaching 60K miles. I have read the warnings on the tensioners and it seems like a no brainer to go ahead and get the top tensioners replaced (I will have a mechanic do it).
Everyone recommends the top tensioners be done but many seem to put off the lower tensioners -
Question is:
Is it simply because it's a more difficult and costly job or are the lower tensioners less prone to cause a catastrophic failure?
Any idea how much more difficult it is to do the bottom tensioners too?
Question is:
The bottom tensioners are less prone to failure than the upper secondary tensioners. Replacement means removing the front engine cover for access and all of the things mounted on it.
Normally, with a good scope you can check the condition of the lower tensioners. It isn't the tensioner itself that is the problem but the guide slippers they provide tension to. If they are cracked and chipped they need to be replaced.
The following 4 users liked this post by avern1:
Received 2,643 Likes
avern1 (11-19-2017)
