Replacement battery
If you drive the car most days, you can generally get away with a cheaper acid/lead conventional battery, one with a lower warranty. As you drive every day, it gets charged all the time and tend to last nicely for the price. You will have to periodically (once a year?) check the acid level and add distilled water to make sure the lead parts are submerged.
For the better approach though, get an AGM battery instead. They are maintenance-free and tend to be of higher quality, last longer, and cost more. I have been happy with my Bosch battery.
In the end, batteries are wear items, pay-me-now or pay-me-later type of items. The more the battery is stored in moderate temperatures in the winter and on a tender when not driven, the longer they will last. You seem to already be a champion at that with 15 years on your old one.
The technical numbers are H8/49.
PS: Be sure to re-connect the vent kit
cjd777 (11-21-2023)
I just put another one of these in my 2004 XK8 a few months ago. Its the second one. First one lasted 7 years and seemed fine with zero issues. I just replaced as a preventative measure when I was updating other stuff in the trunk area
Ordering it online you can get 20% discount so ended up about $160
https://shop.advanceautoparts.com/p/...agm/10210828-P
The following 3 users liked this post by crbass:
Received 1,702 Likes
The NAPA AGM LeGend Premium Series is another good choice.
https://www.napaonline.com/en/p/NBP9...dInput=battery
Decided to purchase a Yuasa Silver High Performance battery 100Ah (HSB019). Got a good deal off e-bay. Should be delivered today. However................I have since seen communications regarding something to do with the battery needing a breathing tube. I must admit, although I have not taken out my existing 'Jaguar' battery, I haven't notice a breathing tube. What's this all about? Why does a battery need a breathing tube????
First thing I did after I bought my '03 XK8 'vert in 2011 is change the batt. Got a lead-acid Duralast Gold from Autozone and it has been in there for 9.5 years. Must have gotten a good one ... still cranks strong, no weird electrical stuff going on. Just for grins had it checked and was declared quite healthy. It was $145.99 plus tax back then... looks like AZ charges $159 for the Gold and $199 for the Platinum today. Of course, the warranty long expired.
I also have that gold coloured bolt + my clamp is fitted and bolted through the hole to the left of the gold bolt.
I have always thought it is just there to stop you from placing the battery any further to the rear of the car, protecting the wiring and black plastic box shown in your picture. It also stops you from covering the hole that the clamp bolt fits into.
