Replacement of main instrument pack
I've about concluded that my on-going issue in this thread
https://www.jaguarforums.com/forum/x...please-170497/
is at least very likely to be a failed main instrument pack. I have found a used replacement of both proper year, model, configuration, and even very close to the same mileage as my XKR.
My question for you all is this: can I just swap the current instrument pack out for this used one without need for any reprogramming? Are there risks associated with this if I take the normal necessary precautions with power disconnect/reconnect and wiring harness plug connection integrity?
I have found conflicting information in my searches of the forums, and in my original thread.
Thanks in advance!
Thanks in advance!
Burnham (11-22-2016)
