Replacement Parts Eurospare
The following 2 users liked this post by Paul Pavlik:
Bob OB (11-26-2013),
sshowell99 (11-26-2013)
You will also need 4 shorter Tensioner Mounting Bolts. Ford # W500301*S300 Screw
Some people re-use the original Cam Cover Gaskets, or: FEL-PRO Part # VS50724R
Bob OB (11-26-2013)
My 2 cents...When I did my tensioners, (14 months ago) I used the Eurospare tensioners, the shorter bolts and either a Fel-Pro or Victor cam cover gasket kit (Sorry, I suffer from CRS!), all from Parts Geek. As Paul said, the tensioners are ultimately from an OEM source.
Bob, on my 2000, I didn't rent the tool...instead I used the alternative zip tie method (well documented in the stickies) to complete the upgrade. I believe that the spark plug o-rings are included in the gasket kit. When you put the cam covers back on with the new gaskets and o-rings, pay attention to the torque specs and the tightening sequence and you will avoid future oil leaks! Good luck and enjoy your new found peace of mind.
Cheers!
Jon
Cheers!
Jon
Bob OB (11-27-2013)
Here's my lessons learned on replacing the secondary tensioners.
1. Rotate engine using a 24mm socket and breaker bar on the crank nut to relieve pressure on exhaust cam, then lift cam to remove tensioners.
2. I used Lucas assembly lube when putting the cam caps back on, just a precaution.
3. I replaced cam cover gaskets, can't go wrong for $50. It's worth it.
4. Remove fuel injection relay to get oil pressure to the tensioners before starting engine.
5. Rent inch/pound torque wrench, 90-220 range from Auto Zone, don't second guess torque values.
6. This is an easy job, take your time. Kudos to the FORUM!!!!!
FS[Central US]: 1999 XJ8 Parts or project car for sale Lawrence, KS
casepie
08-30-2015 09:49 PM
