Replacement Steering Column XK8 2003
I checked it out and the bushing, horizontal connection, the one closest to the steering wheel is worn, I can see the shaft move slightly in the bushing. At full up and full down the mechanism rests on a stop and has no play but anywhere between full up/down the steering wheel will move in the 10:30 direction about 1/4 inch, when the wheel is extended its magnified.
The mechanism at the top where it tilts wears. I am not sure if USA/ LHD differs from UK as my parts EPC is on work computer but if you get stuck we have them in UK.
You probably just need the central unit. You can take the motors off your old unit. The motors and reach cable fetch a premium.
I hope that helps
Ben
I hope that helps
Ben
Jandreu (12-31-2017)
Anthony8858
09-05-2016 10:48 AM
