Replacing Differential Pinion Seal
Jag: It's pretty involved. Your going to have to drop the unit I am guessing.
I discovered this just trying to change the oil at the tranny shop. They couldn't even reach the drain plug.
The good news: The guys at the shop said it looked like a Ford unit, and that will save you some money.
Your dealer probably wants to replace the flange with the seal as that is the way Jaguar sells it now. If you can find an independent to just replace the seal, you should be able to save some money (I didn't realize someone sold just the seal until after I had mine done)
Coventry West sells just the seal and if you look around you may be able to find someone in the UK that does the same.
JagTheRipper (11-06-2011)
KarimPA
09-03-2015 07:32 PM
03, 2001, differential, difficult, dirrerential, jaguar, pinion, rear, replace, replacement, seal, seals, typepdf, xj8, xk8
