Replacing drive belt tensioner and pulley
I have not done the tensioner on the drive belt but have done the pulley. Its should be a matter of removing the center bolt and the whole assembly should come off. I would think there would be a specific locating tang so it goes back in the correct position. Since there are no other parts associated with the pulley you could go in blind. A way to check this idea is to get the new part and look it over, it should be evident what kind of diffuculty you would be getting into.
Use a 15mm socket on a breaker bar on the idler pulley, top pulley in photo. Then turn it to your left,car's right. This will take the tension off the belt so it can be removed. Remove the tensioner with 13mm socket, under idler pulley in photo, and remove bolt and tensioner will come off. Reverse procedure for reassembly.
Markmbaha1 (10-13-2021)
Also remember to make a diagram/ take a photo of the belt where it runs etc.
You may think its obvious when its on but once its off its head scratching time ........... now did it go over or under that pulley?
Good point about the reverse thread.
I changed both of mine when I first got the car. No special tools just my tool kit and a lot of grunting.
The following 2 users liked this post by johns55:
Markmbaha1 (10-13-2021),
Zeronine09 (06-04-2021)
BrentGardner
28
04-26-2024 03:08 AM
xjrjag
10-27-2021 11:48 PM
Fraser Mitchell
10-01-2015 04:06 AM
