Replacing Lower Wishbone Bushings
I need to replace both front lower control arm bushings. I have searched the forum and the internet in general, but still have some questions.
Do I have to remove the entire wishbone assembly? Or can it be done while in place?
I am going to use powerflex poly replacements which will just push in, but will the OEM units have to be pressed out?
I assume I will need to put a load on the springs during the process, correct?
Any general tips or cautions on this procedure would be greatly appreciated.
Just my 2 cents... I would be replacing the ball joints lower and upper at the same time and if you haven't replaced the front shock I would replace at the very least the lower bushing as well if not the shocks and upper mount. Ball joints are a bit tougher and will require a 20 ton press but you will be so much happier to have a fresh front end.
Jag#4 (06-26-2016)
oldish git
27
07-24-2020 02:05 PM
clivedavies
04-07-2016 10:21 PM
