Replacing the timing chain tensioner
Good morning everyone.
I have a 2001 Xk8 Conv. And from what I'm reading had better look into changing the tensioner(s).
1. Looks like the issue is the plastic type ends. Is there a tensioner with a different end other than OEM?
2. Other than tensioners and valve cover gasket sets. What would I need to buy.
3. Can this replacement be made by removing the valve covers. Or do I have to take the front of the engine apart??
Any help would be appreciated.
Search the Forum for Chain Tensioner. There are several posts that are quite thorough. The new tensioners are metal but still have a plastic guide that the chain runs on. Your search will provide all the information you need including Lincoln part numbers for a less expensive alternative to Jag parts. (make sure if you go this way you also buy the shorted bolts.). There are even videos of the procedure. Good luck.
If you browse the DIY sticky thread you will see 3 links for tensioners. Just below the pic of the cylinder order pic. This should provide you with the information your asking. A gasket set would be advisable though some have reused what they had. If you pull a plug wire and there is oil you definitely need the set, there are 2 kinds be sure to verify which one you will need. You don't mention miles on your car but it maybe a good time to replace plugs while you have the covers / coils off. And be gentle, the wiring can be brittle depending on miles / use. You only need to remove valve covers.
Shelorr (03-09-2016)
Received 2,623 Likes
Do not reuse any gaskets or seals as this is false economy. I have not had good success with aftermarket gaskets or seals and can only recommend the Jaguar parts, especially for the cam covers and spark plug boss seals.
edankeven
28
03-08-2023 05:03 PM
JagnJeep
03-07-2016 05:33 PM
Lagonia
03-03-2016 09:18 AM
