Reset door window
Run the window and hold the button until the window stops moving and you hear a click about a second later. You need to get the click in both directions.
DavidYau (03-13-2020)
Probably low battery charge
Get battery tested. Most garages will do it for free. If it’s old, just get a new battery. If car isn’t driven often, get an intelligent battery minder/tender to keep the car battery charge up.
If situation continues, you have a battery drain somewhere. Pull fuses until you see current draw is low approx. 150mA
frankc (03-15-2020)
99xk8guy
06-05-2023 06:28 AM
