restricted performance
Received 4,302 Likes
magnum454 (09-26-2017)
You can use this link to identify what the code is telling you the problem is.
Link to codes http://jagrepair.com/images/AutoRepa...7_ECM_2000.pdf
The problem could be in one of your coilpacks but I thought it would have thrown a code for that coil and did not. The problem could be in the ECM and the only real way to know is to send it out and have it tested. If it comes up again and a coilpack does not come up you might want to get the ECM checked before it lets you down on the road.
Sorry but I did not see the code the first time. Always a problem for me reading a post on the phone.
You have an intermittent problem, and fortunately it persisted enough to produce a code. If you were less likely, you'd get no code or leads. You can assume you are on borrowed time, and you can use that time to prepare to address the ignition coil problem, typically by replacement. Good luck.
My Restricted Performance was associated with a Knock Sensor code. I replaced the Knock Sensor and solved the problem.
