Restricted performance
I am once again dealing with multiple check lights and restricted performance only to have the car run for a week or two with absolutely no issue once I restart. The ABS and Stability control faults are announced on the dashboard and the car drives at about 5 MPH with Restricted Performance illuminated as well. What is most troubling is I can restart and their is no light warning light of any kind remaining. I have been in several locations where I barely was able to pull off the road.
I have read that this can be the throttle body, low voltage (new battery and was checked with alternator - both fine) or some mystery circuit board in the engine compartment that has bad solder joints. I have also read the codes and they seem random at best - any advice??
DallasJagBoomer
10-15-2018 09:24 AM
10-08-2012 04:24 PM
