Restricted performance message 2001 XK8
After an engine swap I had a check engine light and Restricted Performance message. I had numerous fault codes which I cleared, but I still have the check engine light on and Restricted Performance message. I checked and I do not have any new fault codes. I do have a battery not charging message with red and amber warning lights. I also have the ABS light on.
I have 13 volts on the amp gauge with the engine running.
Thanks for your help.
