Restricted Performance On and Off
P0302 Cylinder 2 misfire
p1313 Misfire Rate Catalyst Damage Fault Bank 1
P0352 Ignition Coil B Primary/Secondary
P1111 System Pass
If I'm reading this and the engine cylinder diagram correct, I need to replace Coil B, which is the second cylinder in Bank 1 facing the engine. Does that make sense?
THanks
![Restricted Performance On and Off-jagv8fireorder.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/200619d1501687747t-restricted-performance-off-jagv8fireorder.jpg)
jeremys (08-02-2017)
My XK8 with restricted performance message first and then no-start problem is repaired now. It was one of the ignition coils that had been shorted as bad as getting overheated and the plastic had melted. It blew the fuse for the ignition coils. Replacing the coil and a new fuse fixed it.
