Restricted Performance question
With the codes you are getting it could be the coil pack, spark plug, coil relay or injectors. With the fact that you were getting only one code for #2 and now you are getting it for #2, #3 & #5 I would be first looking at the plugs and relay then the possibility of the injectors need cleaning. At times a can of BG44K added to the fuel is all you need but it is hard to say. And yes a low battery could cause this problem.
Link http://jagrepair.com/images/AutoRepa.../jagxk2000.pdf
robert53 (09-10-2018)
Received 2,677 Likes
Before changing any additional parts, check the battery voltage across the terminals after the ignition has been of for at least ten minutes. There should be a minimum of 12.6 volts across the terminals or the battery should be replaced.
If the battery has proper voltage, next check the fuel pressure at the schraeder valve on the fuel rail. Fuel pressure should be between 3 and 4 bar at idle and 5 bar at WOT.
Just checked my XKR - it was 12.8V.
I would check fuel pressure next per the advice (attach gauge to schraeder value after unscrewing plastic cap, I believe at rear of right/passenger side fuel rail underneath plastic V8 cover) - certainly low pressure can throw misfire codes. This happened on my XK8 when the fuel pump was failing - showed up initially in hot weather, when pump had been running for some time, initial pressure was good, then started to degrade after a few minutes, ending up in restricted performance and misfire codes. Also gradually lost ability to hold pressure after engine switch off. Of course you have a relatively new pump, but I suppose it could be a dud, or fuel pressure regulator issue, or....anyway I would follow the advice to eliminate low fuel pressure as a possible cause.
#28
It is hard to say if it is electrical or mechanical or fuel. You need to make several checks to identify what is not taking place. Remember this is not your dads Buick! You are dealing with a computer run car and all it takes is a poor connection, bad relay, equipment failure or just low voltage and nothing works right. The best thing to do is step back clear your head and take one thing at a time.
XxSlowpokexX
02-12-2016 02:42 PM
10-08-2012 04:24 PM
