The Results of the XK8 & XKR Hydraulic Hose & Equipment Evaluation
#221
[quote=walt_00XKRConv;462327]
It could be that the threads were crossed at initial install (with a power driver) which would render any removal efforts useless as it is effectively welded in place.
quote]
Walt,
I do not believe the plug was cross threaded on my pump. When the machinist removed the remains of the plug with a reversing bit, it screwed right out. The threads on the pump (and the removed plug) were perfect. In fact I was able to use the pump threads to complete installation of the device. No leaks. All is well after one year.
Jack
quote]
Walt,
Jack
#222
[quote=BlkCat;462370]
That's good info. Based on this I think heat, properly applied, is the solution to the stuck plug. Steel parts threaded into aluminum is always a dicey situation. I think back to my days rebuilding the VW engines. I either couldn't get the bolts out or couldn't get them to stay in.
Assuming the red stuff is Locktite 262, I checked the MSRP and it takes something over 300F to soften it up. I saw a post that recommends 400F which fits with this. An IR temperature sensor is a good way to monitor this. If Locktite is the culprit this would do the trick. Maybe some of the pumps got a heavier dose. I would use a hot air gun with a small nozzle although I saw a post that recommended a soldering iron.
Also, sorry for my confusion regarding the roof problem. There have been a number of people who have had the problem of hanging after the latch has released. I am pretty sure this is caused by the switch in the latch mechanism that doesn't signal the controller. The first step in dealing with this is to clean and lubricate. WD40 is particularly good with switches and a dry lube with the rest of that Rube Goldberg contraption.
quote]
Walt,
Jack
quote]
Walt,
Jack
#223
Yah, I'm bummed too. I considered opening it up to anyone here for a stab at it, ship it to them, but knowing what a replacement costs, I doubt anyone would want to risk it themselves (or via their 'shop') Once that tox bit got twisted in there, drilling through it is impossible.
I know it is more trouble, but if anyone gets the relief valve installed in the future, for the best control, I recommend (and wish I would have) just removed the entire thing from the boot and did it on the workbench. Perhaps my angle was a bit off on the ratchet, maybe a bit of heat before I tried to break it looks makes all the difference. I will sadly, never know.
Then use what we call an 'American Screwdriver" - a small cold chisel - and a moderately heavy hammer to turn the plug. Ususally works
#224
You get the impact, plus the twist-off together for maximum effect.
#225
Using an impact driver accomplishes the same results better... There are spiral grooves cut in the handle, and when it is impacted with a hammer, they cause the screwdriver tip to twist in a counterclockwise direction.
There IS another solution which is to forget the plug (it is just a tap into the high pressure feed of the pump), replace the 90° connector supplying one of the hydraulic feed lines (probably the one next to the recalcitrant plug) with a tee and attach hose 1 to that. Just the same result.
#226
But he's got nothing to turn now. All he can do is try to catch the edge of the plug.
#227
Surely the dreaded plug is just part of the high pressure manifold.
If you're right then the pressure seen at the plug would be high one way and low the other.
There must be solenoid valves to send the high pressure to the relevant side of the rams, I can't see how it could work otherwise.
#228
Good point - I don't know enough to argue. Are you saying the pump motor reverses? I've never heard of such a thing (but that doesn't mean Jaguar can't manage it!)
There has to be some sort of mechanism or configuration internal to the pump that causes the pump body, at the spot the plug is located, to always be on the high pressure side, but I don't know how that is done.
There are solenoids present; one to direct fluid to the "raise/lower top" circuit, the other to the "open/close latch" circuit.
#229
Yessir, the pump does indeed turn in both directions. All the fittings and hoses do reverse roles ... high-pressure / return.
How could anyone pretending to be an engineer commit such an obscenity.
I shall immediately proceed to consume large quantities of French Red Medicine to avoid further psychological damage.
#230
This system was designed in Europe by PowerPackers Power-Packer Europa - Europe
As for the pump it does work the motor in both directions to perform the up and down operation. This link will give you the operating oneline for the car along with charts on the pressures associated with the operation. I hope it helps.
#231
If the broken part of the torque bit can be removed I would try to use an easy-out bolt/screw extractor. With a little heat and the right size extractor it could come right out.
Extractor Sears: Online department store featuring appliances, tools, fitness equipment and more
Gordo I do not have the Impact Driver but it is on my list of things to get.
#232
Am I being silly?
#233
The pump information is not on the link to PowerPackers I forgot to add the other link.
Pressure charts JagRepair.com - Jaguar Repair Information Resource
The wiring diagram http://jagrepair.com/images/AutoRepa...eline99xk8.pdf
steveinfrance (03-12-2012)
#234
Received 6,310 Likes
I was having a poke around mine recently and I see the pump is only anchored with two bolts on the one side and sits on rubber mounts on the other.
This would indicate that it rotates in the same direction all the time otherwise it would tend to lift off the mount in one direction.
Just a thought that was bothering me.
#235
A pump that works in both directions? As in its rotation is reversed to achieve a different result? Just how in the heck does that work and why would anyone engineer something so bassackward? Centrifugal pumps provide pressure in one direction because they only work efficiently in one direction. Piston pumps only push in one direction no matter what rotation because they employ one-way check valves. The valving beyond the pump is opened and closed in order to achieve desired results.
I admit I haven't kept up with the entire thread and I'm jumping in here at the end, but...
#236
Dennis, are you sure this is the case?
Yeah, I think it's pretty well nailed down that the pump does indeed turn in both directions. Just a thought or two about this for tonight -- I'm on the fly -- we can kick around tomorrow if you wish.
The schematics make clear that the voltage to the pump gets reversed at different stages of the raise / lower top cycles. There is no reason (maybe better to say none I can see) to do this other than to reverse the direction of the pump, of the fluid flow.
The hydraulic circuits are consistent with this, and the only valving is a pair of solenoids that direct fluid to either the ram circuits or the latch circuit but do not change the direction of flow. These circuits are push-pull arrangements in both cases. In other words, push fluid this way to (for example) close the latch; push it the reverse way to open the latch.
The anchoring of the pump ... as I recall there is rubber on all four points (it has to be isolated to permit the voltage polarity to be reversed) but I don't recall anything that indicated the pump would not be supported rotating either way. Maybe you saw something I did not.
How do you see it?
#237
#238
I did forget about swash plate pumps but a) there's no reason to reverse their rotation and b) there would be no reason to use one in this application. However, a little googling shows there are quite a few reversible pumps out there. Most seem to be low-power/low-flow types but I may not be looking thoroughly. It would answer my doubts to efficiency. See: SPX Fenner Reversible Hydraulic Pump Testing, Hooked to a White's Hydraulic Wheel Motor. - YouTube then: ENERPAC -* HYDRAULIC, OHS INC. COMPANIES SINCE 1953, ENERPAC, BVA, HEIN-WERNER, POWER PACKER, POWER TEAM, RAM-PAC, TK SIMPLEX. for a dealer/repair shop that handles PowerPacker, et al.
#239
I think the original 'design' came from Holland. It does look like something produced while smoking herbal tobacco.
It does definitely reverse but there's no external torque if you think about it so it doesn't need anything more than location from the mountings.
The whole setup is awful.
Why didn't they run steel brake line type pipes under the chassis with short flexibles where needed. That's how all normal hydraulic machinery does it.
The flows are so small (particularly to the front latch) that you could get away with very fine bore tube.
#240
