The Results of the XK8 & XKR Hydraulic Hose & Equipment Evaluation
#81
#82
#83
#84
Having the "tall tier" setup it would be difficult for me to get to the filler fitting on top of the reservoir without essentially moving the motor/pump off of the rack.
Doug
#85
#86
#87
#88
#89
#90
Another quick question. I called the local dealer to see about the fluid and they sell for $70.80 for a quart!! I did confirm that the local NAPA sells Pentosin CHF11S for about $20. I just wanted to make absolutely certain that the Pentosin is the same fluid as what Jaguar uses--yes?
Thanks,
Doug
Thanks,
Doug
#91
#92
Well I got the Pentosin from NAPA ($22.99) and did the fill. I used the "turkey baster with tubing" method and am not all that sure it saved time over removing the pump for better access. I did find that one of my 1/2" open ended wrenches worked (although another 1/2" wrench was too small). Once partially loosened with the wrench I found it easier to take a 9/16" socket and turn this with my fingers. With the tall-tier setup like mine if you have big hands forget about it.
The other problem I had was with the baster-tube setup. I was able to snake the tube in to the filler hose and then poured the Pentosin into the open end of the baster (I lost the rubber top). But the fluid would not flow into the reservoir because the tube fit too tightly into the filler hole (not allowing air to come out). So I had to blow into the baster to force the fluid in (sorry if this is starting to sound like some erotic novel). It finally worked and I will keep an eye on the level.
Doug
Doug
#94
#95
A while back I ordered this kit from LSI and last week I picked up some Pentosin CHF 11S from the local Mercedes Benz dealership. Today I finally got the time to do this. I overestimated how long and difficult it would be. It was incredibly easy to install and the instructions are wonderful. I think someone who had never done any mechanical work could easy do this. I heartily recommend this modification to anyone with a convertible. I don't know why something like this didn't come from the factory. Walt, Gus, everyone, thanks a million for all your research and work on this. I'll sleep better at night now
Hopefully tomorrow is nice so I can drop the top.
Just so people are aware:
I did this same thing.
Originally Posted by mbalce
The only glitch I ran into was the hole where I removed the T30 plug on the inboard side of the pump right by the latch hose, which is on a 90 degree coupler was just blocking the ability to get the new hose threaded on…I ended [up] backing the latch hose off the coupler about half way. Did not even need to remove it, just loosened it about half a dozen turns or so. This gave me just enough clearance to get the new hose started in the hole and once that was all the way in I was able to re-tighten the latch hose.
#96
#97
Ken, thanks for the feedback. Several kit installers have run into the interference you mentioned. It depends on how that elbow was installed. There is no problem with moving that elbow slightly clockwise but most have done what you did. Yours is definitely the low risk method as it is the coupling nut on the fitting that gets in the way. The prototype in my car used a short pipe nipple to space things out but that leads to a Rube Goldberg mess of fittings so in the end it was decided to keep it as simple as possible in the name of reliability.
I have been contacted by some people with other cars that have similar Power-Packer roof systems that have exactly the same problems. This includes the infamous Polyflex 363 hose that seems to be the root of the evil.
#98
Thanks Gus for a good advice on the telephone last week. I got my hoses made wit JIC fittings - (a local dealer 60 miles away does not stock them) and stripped everything above a dashboard. Now I am stuck. Is there anywhere available a TSB how to remove a left kick panel, door sill and how to get under the carpet. I assume that all these parts are somehow snapped in, but I dont want to apply to much force on anything - so far mild force did not help.
#99
#100
