Rigidness of the convertible?
How rigid is the convertible, particularly at the a-pillars? Through regular driving, I can see a lot of vibration going through my rear view mirror. I'm not sure if this is just indicative of most convertibles which do not have a roof or b & c-pillars to keep every thing rigid above the window line. The XK8 is my first real convertible. The last car I had without a roof was a Wrangler, but that had roll bars connecting everything tight together.
I know in my daily driver stationwagon, there are hardly any shakes noticed in my rear view mirror when I drive.
If you are talking about structural rigidity, e.g. Cowl Shake, then I think my 97 is pretty flimsy. I have a lot of body flex. The difference with the top up and windows sealed is readily apparent. I think the 93+ had some additional unibody strengthening, especially under the rocker panel cavities; but I have not been able to confirm this.
I would certainly like to hear from anyone who has ideas, or knows about, strengthening the chassis on these cars. The flex is my only complaint in an otherwise superb auto. gordo
I'm going to remove the stem cover and see if there are any screws or nuts to tighten the mirror. I didn't see a tab or opening to take the cover off, would you know of a special way that needs to be done? Thanks!
Well, I got the two plastic covers off fairly easily. And that was the only part that was easy. The metal rails that connect the mirror to the windshield are worn prohibiting a tight fit. Efforts using thread tape, then silicone, were unsuccessful. Then, of course, an hour later, the simplest solution is always the best. I used two layers of double-sided foam tape between the windshield and the mirror stem to fill in the gap caused by the worn rails. That fixed the looseness at the stem closer to the glass.
Unfortunately, there still a very slight little bit of play further down the stem towards the mirror, perhaps at the ball/joint. I may look into a fix for this later.
vinny jones
10-05-2015 07:20 AM
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
09-07-2015 04:28 AM
