RIP CD Changer
It looks like my CD changer has finally gone to the Great Electronics pile in the Sky( or needs to). Is there a remanufactorer in U.S. or other wise who will reworks these units? I have about 120 CD, and would like to us them as well as keep some parts of my XK original. Not a big fan of 'bluetooth, streaming', or whatever.
Received 1,686 Likes
pulled anyway it’s something to consider.
I think you will be able to find a CD changer on eBay easiest.
Z
PS. I had to shop for for a replacement amp recently and there were many to choose from. I wasn’t sure the amp was bad (had no way to test it) so was shooting in the dark. That considered I purchased the cheapest one on eBay for $32 & change. I lucked out and the new / used amp fixed my
problem and is working perfectly,
That is my plan of attack right now. Just bought one from eBay that I hope will work. I bought one that was supposedly "Remanufactored". Put it in and it would not eject the magazine that was in it. Do not know if it was mag or what, but sent it back.
Now I have pulled the amp and navigation unit. Since I replaced the nav system with 3 gauge system do not need nav box. I managed to remove the Nav unit from the rack, and still have radio and tape. Plan to sell the Nav unit for $25 + postage if anyone is interested. I may have a Harmon Kardon amp coming. Do not know if it will replace my existing amp or not.
Received 4,317 Likes
Sam,
Don't they have an Auto/Radio Shop in Florida? I had this problem a couple years ago and took it down to the Shop and they pulled it out and messed with it for a few minutes and put it back in and it is still working for $25.00......I also have an extra one in case something happens ......can't go without my CD's......Biggest problem I've had is with the CD's....if it is one that I bought, they seem to work better and longer than one that I recorded......Don't know why! I got a player in my sound area in the Den that holds 100 CD's and I play it all the time....The fastest way to get it going is to find one of those Auto Radio Shops......You drive -in and they pull it out and mess with it a few minutes and pt it back in and charge you $25.00 Bucks and off you go!
Billy Clyde @ Cinco Ranch
B.C. et al,
The changer began stopping during the CD change out( CD 1 to CD2, etc., then giving and "Error" code. Magazine would then be locked in and would require extensive 'giggling' with a putty knife to remove the cartridge. Eventually I could not get the CD to play without getting the error code.
I went to local Radio/auto radio shops to look for repair. No luck. Few people locally use CDs(I think most of our residents still use only AM radios). I was recommended to a shop in Brea, Calif. 'Mossaoud', said that they have limited parts, but he would go through it and see if he could fix it. Worth a try. Meanwhile, I have ordered a replacement through ebay(first one did not work). Will see if this one does. I also pulled out the Navigation unit(replace Nav system with 3 Gauge unit). I plan to list the navigation unit, without the display, in the classified section since I do not need it anymore.
Once all is reinstalled, I will have a space between the amp and CD changer. Hope to rig some type of storage for my CDs. I have about 120, so I would really like to use my in-car player.
B.C. et al,
I have about 20, 6 disc magazines. Most seem to be in good shape. I think the problem is the drive mechanism inside the changer. Someone has said that it is a nylon gear that becomes worn. Hope the guys in Calif. can fix the problem. I am starting to collect a few backup changers, I think. Just hope they work.
Still need to get rid of Navigation unit.
Sam,
I have an extra CD Changer hidden away....Just in case the one in the Car decides to quit.....Every time I've had a problem, all I've done is go down to this little Radio Shop and they pull it out and do something to it and charge me $20.00 and it starts working again.....Been OK now for 3 or 4 years....They are the Guy's that told me about using the "Copies" rather than the Original CD's....Apparently, the Copies are thinner or something and they will cause it to hang-up inside....I've tried to use original CD's since....Try that!!!
Billy Clyde.
Billy Clyde.
