Roaring Sound -- Thought it was tire noise
I began to hear a roaring sound that I was so sure was tire feathering or a bad tire belt that I replaced the entire set. The tires were replaced with the top down and when I drove off there was no noise. Unfortunately, with the top back up, the noise is still there.
Sound likes driver's side but I cannot tell if front or rear. Worse at 35 to 45 miles per hour. At slower speeds it has a irregular sound.
Seems to be mitigated somewhat by applying the brakes, but I can't think of a brake issue that would cause the roaring sound.
Anyway, I had the rear axle fittings greased recently. The diff fluid was replaced a few years ago and has less than 20K since. The car has just turned 71K,
Thoughts? Thanks!
Thoughts? Thanks!
Madbrad (06-04-2016)
Could it be a warped brake rotor? There is no shutter when braking, so I had ruled that out, although the noise seems to go away when hitting the brakes. There is no discernable noise with the top down.
That sounds like a distinct possibility Gus. Does the mileage 70+k sound about right for that? And, how long can I go before replacing if that is the case?
Thanks again Gus. I will jack up each corner and check for wobble. First thing tomorrow before I drive again.
There's a chance that either all of your bearings are warning you, or you have a combination of bearings and bushing issues.
My wheels are very tight with zero play either side to side or up and down.
On the 97 K cars, you will notice a slight bit of play when moving the rear wheels (pushing on the top and bottom of the tire). This is normal but is not coming from the rear hub bearings but rather is normal movement in the axle bearings in the diff. But, the front are sealed bearings that are zero tolerance. There should be no movement in them at all! If there is any, they should be replaced. They are a common issue.
There is a lot more play in front wheels from the inner tie rods. If the wheel bearing is going bad it would be very hard to diagnose by wheel play. Like Torrid, mine were bad at 80K miles, but there wasn't play from the bearings.
Drive about 30-40 mph and change lanes. If the roaring increases/decreases during the lane change, its the front wheel bearings.
