Rubber pigtails
Received 2,380 Likes
I'm asking because I have recently bought an XK8 and amongst other rear end rattles there's an awful metal on metal creak that happens from time to time. Yesterday I put a lot of silicon grease spray near the pigtail and it's a lot better which of course could be coincidence. But possibly not. If that pigtail had split or wot not then maybe it's the source of the squeak.
I assume it is a complete circle so I can't fit a new one without dropping the shocks etc. which in fairness I'll probably have to in order to cure the rattles - but one step at a time!
Check the lower shock bushings:- they're a common failure and could cause a rattle
