Rule of Thumb for Changing Spark Plugs/Wires and Fuel Filter?
Is there any rule of thumb that says when the sparkplugs/wires and fuel filter should be changed? I have a 2001 XKE convertible with approximately 84,500 miles on it and wonder if it is time to change, since I am getting restricted performance codes related to engine misfiring. This is only an intermittent problem and I am puzzled by what might be causing it. Could it be the spark plugs, the wires, the fuel injectors or the fuel filter? How do I tell my mechanic to troubleshoot this problem so I don't get soaked with a huge repair bill that does not fix the problem?
spark plugs
Hey:
I got my car a couple of years ago. 82000 miles 99 xk8 convert. She was missing a bit so cleaned the maf and part load breather and decided to change the sparkplugs. Car ran better but I did learn something. It is a good idea to change them even if they dont need it as a couple of mine were very very tight. I guess with age they tended to seize in a bit. So I would recommend at least maybe taking them out and putting anti seize compound on them as a just in case
Howard
Howard
Charlene n John
09-28-2015 06:01 AM
Wes Steenrod
09-06-2015 06:52 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
