running bad
Trouble Codes
Here is the trouble codes from the manual. From the sounds of it and looking at the codes i would start with disconnecting and cleaning the connectors for the ignition modules and the ecm. if you have cleared it before and it ran ok then it could be just corrosion. you could also swap locations on the modules and see if the code change to the new cylinder location. your current codes are for cyl 1, 7 4 and 6.
Welcome to the forum bigcat. I just noticed that was your first post. When you have time please visit the new member area and introduce yourself:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
http://www.autoecu.com/
Wolfy
05-28-2024 08:06 AM
