Runs rough after injector replacement?
I recently had to replace an injector due to a warn O-ring. After replacing the injector the car still runs rough but not rough enough to put it into fail safe mode or throw a code. I replaced the replacement and it still runs rough. All electrical connections seem intact. Any ideas? Is it possible to have a single cylinder wash down?
jobagadonuts (10-16-2017)
I would think a single cylinder bore wash would be pretty unlikely plus after running bore was goes away. Have you checked to see what codes are showing up. It is possible while you were in there that you disturbed something causing a misfire elsewhere.
Read the codes and get back to us.
The o-ring crumbled when I removed the injector. Most likely others are in the same shape, looking to replace all the injectors ASAP. It runs better the more I drive it. Perhaps I fouled a plug in the process.
jobagadonuts (10-17-2017)
