Rust prevention XK8
It appears as if that plate is part of a reinforcing bridge that connects the front frame extensions to a more outboard section of the cowl/firewall. this obviously provides side to side movement stability and most probably torque control of the front frame extensions. by connecting the floor pan it also keeps the car from sagging. the floors become a tensile support in the way road sections are held together in a cable-stayed bridge. in any of these cars but especially a convertible this should be in place and complete in good order.
this is the result of the old XJS platform being repurposed. the forward frame extensions were definitely completely redesigned. if you remove the wheel well liner, the 45 degree plate between the forward extension and firewall bulkhead becomes apparent. it is also obvious that it turns 90 degrees to travel along the underside of the floor pan. by extending in this manner the welds along its length spread out the load over a greater distance along the floor pan much like a stitched fabric uses many individually weak threads to achieve greater strength along its seams.
the nice thing is that the area between the plate and floor is open at the 45 degree section in the wheel well and there are some underside drain holes. this situation makes rustproofing very easy if one is not against making one great big mess.
a hot rod builder looking over the underside of my car verified this when he said that our cars looked like custom builds where something was well modified from another vehicle.
it is the history of the car as well as a very necessary structural member. it must be present and if repaired done properly which probably means replacing the complete plate from the wheel well area around to the floor pan.
i recommend the corrosionfree product for preventative maintenance. you will have a mess when you do it, but it does not make you feel like you ruined the car. and i advise doing this job yourself as the applicators might not know this car or being willing to dismantle to work on this area.
take out the wheel well liner and look at where the front of that plate goes. it is part of the 45 degree brace between the forward frame extensions and the firewall bulkhead. designers do not install parts without reason.
I don't think anyone said it was there for no reason, but that reason is widely acknowledged as being part of the production process, not part of the rigidity of the car long-term.
