S-Type steering wheel in XK8
So I asked a question on here a while ago about getting a track backward button on my XK8 steering wheel, and I just thought: why not use a different model?
Will the steering wheel out of a 2003+ S-Type work in a 98 XK8? I had an STR a few years back, and I remember the steering wheel to be much more to my liking; all leather/no wood (I am redoing the cracked dash wood in piano black), thicker wheel, nicer shape, etc.
So will the audio and cruise controls work? How about the airbag? Anything else I'm not thinking of?
I've been wondering this too, since I have a 98 xk8 and an 04 x type and I like the x type wheel a lot more. I do have an extra x type wheel sitting around so if there isn't an answer to this I might try it out and see. I don't have an extra airbag though. I do know that the older x type wheel and the new x type wheel are interchangeable, and I think the s type and x type wheels are also interchangeable too so, it might work.
metalmarty (08-07-2014)
I'll start with the steering wheel. lol
Someone here has to have an answer for whether or not this will work. The mounting is fine I'd assume, but I'm concerned about the airbag and audio control functions.
I would like to bring this thread back to life for a bit to ask the question differently. I no longer care about the audio controls, as I have decided on an aftermarket head unit, and I will be able to get an adapter to make the audio controls work with that.
Now the only issue is the airbag. Does anybody know if the airbag connectors are the same in the XK8 and S-Type? Maybe someone has removed a steering wheel at some point and happened to take a picture of the connector?
Removing the wheel
Removing the wheel is maybe a 30 min job if you are slow. What took me extra time was disconnecting the air bag wasn't obvious (I was trying to disconnect at the wrong connection). It's just 4 screws behind the wheel to remove the airbag then disconnect it and the stereo/cruise controls then the airbag and finally remove the center nut and pull the wheel. All you need to do to check is pop the airbag, check the connectors, and reassemble. Likely take you less time then looking things up on the web.
I replaced my wheel a few months back, unfortunately I didn't take pictures or I'd post them.
metalmarty (09-12-2014)
Paddles
Not trivial. I looked into it. There is one kit in the UK but you have to get the car to them to get it, they won't ship it to you. I've had a couple folks that do this in the US look at this and you can get a motor to do it for about $3,500 plus installation and there was no guarantee it would work. So it can be done but it is such a pain that it doesn't appear to be worth the effort. On the XKR, at least my year, you'd think you could adopt the XK150 components but I don't want to be the first. On the XK150 wheel last I saw he was still struggling with the stereo/cruise interfaces. As a side note I had a friend, who does this for Mustangs, create a kit that would allow you to use the switches on the steering wheel for other things (like paddles) but when I hit the wall on the transmission I couldn't figure what else I'd use them for.
I have an idea, I have always wanted to be able to control the a/c without having to extend my arm to the center console.
I've always wondered why this is possible in my Mercury Marauder and my Lincoln, but not any of my 3 Jags. They were all owned by Ford at the time, so why didn't they think of that?
Air Conditioning
I could hook you up with him if you want to try this. But basically they remote to solenoids that you'd have to wire into the air conditioning controls without cooking anything. Generally the mustang guys use these for nitrous or brake locks for drag strips. I'm still a bit tempted to try nitrous since heat is now my biggest problem to solve..
giandanielxk8 (09-15-2014)
rusty37
04-05-2020 07:40 PM
