samdurrant XK8 help
Hi guys, samantha ere, can anyone help me please.... my 1997 xk8 convertible needs its ecu resetting, it was an accident damaged car i bought, both airbags deployed & went through the windscreen, those have been replaced and so has the radiators....i now have warnings lights flashing, and it's telling me that a genuine part hasnt been used on the suspension.. all parts replaced are genuine... can anyone help with re reset please..
Received 6,332 Likes
Received 9,011 Likes
Welcome to the forum!
You would get a lot more traffic over on the XK8/R forum but here are a couple thoughts from your limited information.
1.) Ensure that the battery is completely charged.
2.) Remove the negative cable from the battery and hold it to the positive post for a few seconds.
3.) Report any OBDII codes stored.
...and if you don't have a code reader, most auto parts store will read the codes for free. Get the code numbers from them, come back here and post up the numbers.
You can also buy code readers pretty cheaply these days. I've seen code readers in auto parts stores for $60, and you can buy them on eBay for $40 or so.
This thread might help you locate your inertia switch.
https://www.jaguarforums.com/forum/x...-advise-47463/
Can anyone tell Samantha how to reset it if it is tripped?
Not sure where to start on your problem. You say you replaced the ECM this TSB might apply http://jagrepair.com/images/TSB/XK8/...patibility.pdf It addresses a compatibility issue that might apply. I am also attaching this TSB addressing ECM Replacements http://jagrepair.com/images/TSB/TSB2...eplacement.pdf With the flashing lights and other things not working you should see if you can get the OBDII codes to see what direction you need to go into first. You may need to document what you have, clear them and read what comes up the next attempt to start. I had never worked on a car that was involved in an accident so I am not sure what things to check. Checking the inertia switch as suggested for the fuel is a good idea. It being activated will eliminate power to the pump by reenergizing the ignition relays in the engine compartment, drivers side fascia & trunk fuse boxes. It also removes the ground from the BPM. In short it stops the engine and fuel pumps, unlocks the doors, de-energizes all unnecessary electrical systems and this might be part of your problem. I hope this helps!
