SC Coolant bleeding
SC Coolant bleeding
I just replaced a Norma connector with new heater hose, clamps with a brass barb. Would like to thank Jon89 & motorcarman for their help.
Here is an after photo...
So my next task is obviously to fill and bleed the coolant. I didn't drain the old coolant but just let the coolant drop from the pipe & hoses. It is about 1/2 gallon in the pan.
My question is: do I need to crack open the SC cooler and bleed it (I found it from a XK repair guide)? I checked with my local Jag dealer and the intercooler washer is a special order and it will take at least 7 days for delivery. Therefore, I would not open it, unless I really have to.
What would you do in this situation?
Thanks in advance as always.
JW
JW
Received 1,702 Likes
Good to know that it's actually reusable. If no leaks, I would be happy. Thank!
