SC Removal Help
Hi Guys,
I'm in the process of removing my SC and Intercoolers in order to replace the valley coolant hoses.
I'm having a hard time removing the lower intake elbow. It's free and there's play, but it's still relatively tight and there's not enough room to take it out.
I'm following the workshop manual and have removed the TB, disconnected the EGR, and disconnected the coolant "bypass V" that connects to the intercoolers. The bolts on the sides were also removed, per the Jag shop diagram, as were all vacuum and electric connections as far as I can see.
Any ideas? Should the "bypass V" be out completely before I can remove the elbow? Do I need to remove the EGR valve out completely?
pomosv (12-30-2014)
Recommendation on the polishing, have the intercoolers media blasted first to remove the paint. Not sand blasted, that's too course but something like baking soda.
Polishing the large flat areas will work well but you will likely have paint left in the welds and between the lettering. I ended up cleaning mine by hand after the fact and then redoing some of the polishing.
Maybe one of these places can help you.
Iceberg Dry Ice
Dry Ice Blasting BC | Welcome to Razor-Wash ? Serving the Lower Mainland, Fraser Valley and Vancouver Island ? including Vancouver, Chilliwack, Abbotsford, Langley, Victoria, Nanaimo and Beyond
MES Services - Dry Ice Cleaning | Mes Services
Dry Ice Blasting & HRSG Cleaning, Surface Preparation - Precision Iceblast Corporation
Iceberg Dry Ice
aholbro1
08-05-2021 05:02 AM
doctordeuce
09-12-2015 08:30 AM
