Seat Control Module
Seat Modules
Yes i have switched mine back and forth when testing to determine if the passenger seat module was defective. If you search you will find other threads with how to repair the modules. the most common problem seem to be minor breaks in the circuits due to abrasion. my passenger seat will lean back but wouldn't come forward. After repairing the break it is working fine now.
riverrob (07-02-2014)
Here is a link to an individual that does module repair. https://www.jaguarforums.com/forum/x...dation-103908/
Mine still works 8 months later.
riverrob (07-03-2014)
Sneaking a bit off topic, are the 'brains' for the electric seat heaters in the seat control modules? All mechanical functions for both of my seats work perfectly but the driver side (RHD) seat heater is not working. The red LED on the dashboard on/off push switch isn't lighting when pushed either. The passenger side switch lights when heat is asked for and the seat heats.
Can big hands get at the seat modules or do I need to do a 'seatectomy' to pull them so I can do a module test swap? If the swap works I'll get inside the defective module and look for solder breaks or get a replacement.
RB
RB
East Haddam (07-05-2014)
Undo the seat cushion at the front by removing the nuts that hold it to the seat frame, lift up the seat cushion, and remove the seat control module. This is much easier than removing the seat, especially if the seat won't move front-to-back because you have a problem which is why you are removing the darned thing! Seat cushion has a nut on each side near the front. I think the nuts are 13 MM - easiest with a ratcheting box end wrench (AKA ring spanner). Seat Control Module nuts are 10 MM.
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
