Seat control module
#61
#63
If you are speaking of the seat module try one of the two http://forums.roadfly.com/forums/jag...9317317-1.html or http://www.jag-lovers.org/include/iv...aYyDO5FA%3D%3D If you are looking to repair the headrest use this link https://www.jaguarforums.com/forum/s...ad.php?t=40347
#64
The case is availible seperately. As far as repairing these I dont know how to solder the circuit on the board but I have had great sucess soldering a wire from the origin of the tracer to the destination. Due to the inherent cause of this concern being the case wearing on the circuit board this repair would be eliminating the cause.
msimowitz (06-15-2012)
#65
#66
#67
#70
I replaced part LJE2160AB/XXX seat module with part LNC2160AD/XXX because seat would not move backwards. Now with the new part the seat heater doesn't work but everything else does. I switched the driver's seat module and the heater works on both seat with that module. So does the new part not have the heater capacity or is it programmable and if so how do I program it? Otherwise, anyone got part LJE2160AB/xxx?
#71
#72
I do not know if this will help with you specific repair Link JagRepair.com - Jaguar Repair Information Resource
#73
kefroeschner (02-28-2015)
#74
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Hello, I just bought my first Jag, and it is AWESOME!! However, the passenger seat module is missing. I called the Dealership, and this part has been discontinued. Any ideas where I can get part # LJE2160AB/XXX
I also understand that it has got to be programmed in order to work, so would need to get one with the coding erased so I can get it reprogrammed by the dealer.
Any help or ideas would be greatly appreciated
#75
#77
#79
If you need a module for the passenger side , I can confirm that a that LNC2160AD seat module is interchangeable with LJE2160AB. The only difference is that it has no memory function ( which the passenger seat does not have
) I just installed an LNC2160AD on my passenger's side and it works fine. The 160AD is much cheaper and easier to find on EBay
#80
Norri (11-11-2017)
