Seat heater performance question - RESOLVED
I must have the wrong idea about California. From TV and forum posts I could understand you being worried if the AC wasn't blowing cold enough but weak heated seats .......?
On the few times I've used mine in previous two XK8's and current XK they do get so warm that they need switching off after a few minutes. However I do think they are slow to get up to temperature.
cyber3d (06-14-2016)
In my X Type, the seats get really hot very quickly, but switch themselves off after 10 minutes whereas in my XK8, they heat up more slowly and to a lower final temperature; they remain on as long as they're switched on.
I interpret that to mean that the X Type heaters are just intended to get the seats to a comfortable level before the climate control sorts out an acceptable cabin temperature and the seat heaters are no longer required. The system in the XK8/R is designed to allow continuous comfortable temperature to be maintained on a long run on a fine winter's day with the roof down.
Just looked at owners manual. As per 1998 manual: Seat temp is regulated so that it goes no higher (hotter) than the temp selected in the dashboard display. I see that as the reason they don't seem to get as hot in summer weather. I knew I remembered something about that. Now I'll probably manage the temp display differently on 30 degree winter nights. From the sound of that statement i realize I can make seat even warmer by raising the temp on the display. Glad you brought this up.
John
John
John
John
polarisnavyxj
05-24-2016 08:45 PM
avtar_singh_7
05-23-2016 10:34 AM
bladerunner919
05-20-2016 08:54 AM
