seat module removal
Good morning all,
I have a drivers seat that will not move at all. in an effort to repair i have checked the #1 and#8 fuses and they are good. I get no clicks from the relays on any function. Since the passenger seat works fine i decided to swap the modules and see if the problem moves. I cannot for the life of me get the seat modules out. There are 2 studs at the front of the module, i have removed them and the module is loose feeling but wont come out on either side. Have i missed more bolts? Is there some trick i need to know? Reading and searching this forum i have read much about repair but i need help getting the modules out. Thanks much
It's been a while since I removed mine, but I believe the 2 nuts have to be removed (technically, one removed, and one loosened). The studs stay in place, attached to the seat. The plastic module is bolted to a steel bracket, and both come off together.
Separately, there are a couple of big plugs on the back side of the module. There is some slack, but not a lot. A tab has to be depressed and the plugs come off, straight out. Resist the urge to use hard tools like a screwdriver. 2 plugs on the passenger side, 3 plugs on the driver side (for seat memory). This is assuming you have 2 seats that are "5-way" adjustable. I have not seen them (might be rare in the US), but I believe there are "3-way" adjustable passenger seats out there as well.
Best of luck, keep us posted.
