Secondary tensioner replacement
Depends . . .
Most will require a gasket set replacement although many DIY'ers probably won't unless there is preexisting oil leaks. FelPro set for the LS is about the cheapest route at $40 discounted at Advance or other.
Ask that the quote include Lincoln LS '02 tensioners/bolts. They are going to be about half what Jaguar parts numbers will cost.
My own experience doing the job for the first time took 4 hours using the full Jaguar cam lock down alignment tool set and procedure. The zip tie method is quicker if your tech feels comfortable with it.
Bottom line: $600 low if the tech is experienced enough to know how easy this is, $800 high
Narda 1 (05-01-2016)
Four hours labor (whatever the going rate is in your area) + parts. I had my indie do it last year and he didn't have a problem with me sourcing the parts (SNG Barratt & Rock Auto). I also replaced the spark plugs at the same time (97000km/60000miles). Rock Auto sells a cam cover & spark plug gasket set for around $US50-$55.
XCrossWindsX
06-21-2016 11:47 AM
FS[Western US]: 2001 Jaguar XJ8
Pilotman11
05-11-2016 03:40 AM
orangeblossom
04-27-2016 03:48 PM
thekiltedwonder
04-27-2016 06:11 AM
