Security module check in boot/trunk
Oh no, I thought this was sorted? When I leave the car for a few days after it has been locked with the fob, on return the fob will not unlock the car, ie it is not recognised. I can reprogram again no problem, I'm a self confessed expert now, LOL's. Could this be the main car battery or something more sinister?
Many thanks for any advice.
Regards,
Arty
Regards,
Arty
The programming is stored in non-volatile memory, so it should not matter that the battery is low, or even removed.
If it continues to happen, the SLM is suspect.
I should add that if the battery was so low that you had to charge it or jump start, then if it did not work immediately a hard reset should have brought it back to operational without reprogramming.
trosty
26
12-18-2022 06:40 PM
abonano
25
09-25-2015 10:43 AM
02jagstype
09-04-2015 08:20 PM
