Security sounder for 2001 XKR
Welcome to the forum Andrew XKR,
I've moved your question from XK/XKR to XK8/XKR forum. Members here with the same model will be able to help.
Received 2,403 Likes
Hi Andrew,
Even if you get a working S/H replacement, it's likely to die in fairly short order as they're all at least 10 years old.
If you're not too worried about having the battery backup, then you might be able to source a 'non-intelligent' one more easily.
Or you might try a repair if it's not too corroded internally. The gory details of the inside are in this thread:
https://www.jaguarforums.com/forum/x...curity+sounder
HTH,
Mike
HTH,
Mike
Looks like for nearly £300.00 yiou might get one here :
Jaguar Genuine Part Number LJB2620AA | Sounder-Security
but is it really worth that expense ? The link above is to a thread I did some time ago - it isn't impossible to dig out the old NiCads and replace them with new, but it is not a job for the faint hearted.
JustNiz
01-24-2017 07:09 PM
