Security system question
Something a bit weird happened today. I had set the alarm with the key transmitter (as usual) and later I pressed the unlock key from a distance. I could see that the car disarmed and unlocked (interior light went on) but I got in a brief conversation with someone so did not get to the car for maybe a half minute or so. The interior light was still on and the door was still unlocked so I got in and started her up (curious that cars are female, but I digress). I put the transmission into reverse and started backing out and then I heard a horn honking rapidly. I stopped since I thought maybe it was someone behind me and the honking stopped but there was no other car. So I put it into reverse again and started backing up and again the rapid horn honking--I realized it was me. I stopped and the honking stopped but, again, when backing up honking started again.
So finally I just put the car in park and turned the key off, waited a few seconds, hit the unlock again on the fob (just for good measure) and started the car again. This time there was no problem.
Does anyone know what happened--I could not find anything in the manual about rapid honking but I guess I was somehow triggering the security system.
Thanks,
Doug
Thanks,
Doug
Received 2,194 Likes
Now that makes sense Anyway, it was just weird in that if I truly tripped the security system, it should have been honking or making noise while stopped and not just while going in reverse. Moreover, the pattern of the honks was like you get from the warning beeps of the reverse sensors (but honks instead of beeps). I guess whatever it was that I did it must have confused the computer.
Doug
