Sensors
Old 06-04-2020 | 10:56 PM
Syb Drylst's Avatar
Default Sensors
Hi y'all,
Does any one know what are the 2 sensors onder the manifold intake of a 1997 jag XK8.
Thanks ahead.
Old 06-05-2020 | 12:48 AM
giandanielxk8's Avatar
Originally Posted by Syb Drylst
Hi y'all,
Thanks ahead.
Knock sensors
Old 06-05-2020 | 12:53 AM
DavidYau's Avatar
Default Probably referring to the knock sensors
Syb,
You’re probably referring to the knock sensors.
Really need to know where exactly you’re referring. A picture would help.
Old 06-05-2020 | 04:15 AM
Does this help?
The following 2 users liked this post by GGG:
DavidYau (06-05-2020), ozbot (06-05-2020)
Old 06-06-2020 | 12:39 AM
Syb Drylst's Avatar
Yes that's the one,thanks for the illustration. Ihave a engine code stated its a knock censor, so what is the function of a knock censor .
Thanks for your help.
Old 06-06-2020 | 12:42 AM
Syb Drylst's Avatar
Thanks David,
Graham send me a drawing which shows where the sensor are.
Old 06-06-2020 | 12:45 AM
Syb Drylst's Avatar
Originally Posted by GGG
Does this help?
Old 06-06-2020 | 12:46 AM
Syb Drylst's Avatar
Originally Posted by DavidYau
Syb,
Thanks David,
Old 06-06-2020 | 01:42 AM
DavidYau's Avatar
Default What is a knock sensor
It’s function is to detect irregular detonation in the piston combustion. The sensor sends signals depending on engine vibrations, and the ECM can make adjustments to stop this “knock.”
Car will be driveable but fairly important to move on this as there’s a small risk of severe engine damage if left too long.
Syb
06-07-2020 11:17 PM
yachtmanbuttson
02-05-2020 08:37 AM
karissatx
08-26-2018 11:04 PM
Gus
06-23-2013 03:06 PM
The Coupe
02-27-2012 11:43 AM
Quick Reply: Sensors
