Serpentine Belt back on question
I have the layout down and will have a serpentine belt tool. My question is what is the easiest pulley to slip the belt over with one hand while maintaining pressure with the other. It was fairly hard to get it off. My guess is from the passenger side to use my right hand on the tool to release the tension try to slip the belt over the alternator pulley. I think that would be my best shot.
Sounds good. I remember I had to slip a 2 or 3 foot long pipe over my wrench to get the leverage to release the tension. Hey David you know how to put the hood in service position right?
Thinking about it, why not thread the alternator and slip the belt over the tension pulley as the final move?
Best and safest way, I find, is to use your shoulder on an extension on a wrench on the sprung tensioner pulley. That frees both hands for the tricky belt section underneath.
1. Place the belt around the alternator, idler and water pump, crank and loose under RHS P/S pump & A.C. pullies..
2. Should still be enough play to put the belt on the wrench before slotting wrench drive into the tensioner pulley.
3. Look towards the car from front go to on RHS put an extension onto the wrench and lean onto the extension with your RH shoulder.
4. That frees up both hands to slip belt onto tensioner pulley
avern1 (06-30-2019)
avern1 (06-30-2019)
hawaiianjag
12-07-2015 07:54 AM
02intrigue
10-25-2007 08:46 PM
